How do I programatically set the simulated Base and noise for a IVI driver?
I have got to the point where my labview VI is using a simulated IVIDmm. The simulation dialog pops up and I can enter the base and the noise values. I now want to enter these progromatically so theat a simulated Labview VI runs without failures.
How do I do this? (I also need to turn off the interactive simulation window.)
Ta BillyB
(2,458 Views)
Under the Simulation Driver Sessions > Initial Setting tab in MAX, you can specify the initial settings for the simulation driver. One of those settings is INTERACTIVE_SIMULATION which you should set to False if you want to turn the interactive simulation window off.
Vesna
(2,448 Views)
