How do I program the SPEEDY-33 without getting this error?
I'm using the SPEEDY-33 for the first time.  I'm using Labview 8.2 with the DSP module installed.  Every time I try to program the SPEEDY, I get the following message...
DSP memory read error. The target hardware is no longer responding. Please verify that the hardware is functioning properly and retry the VI.
Select an item from the list to see its errors. Double-click the error, or click the Show Error button, to highlight the object causing the error. You must click the Close button in this window before you can click the Run button on the VI again.
Any suggestions?
(3,534 Views)
Hi Jimmy1033,
Are you sure you have the SPEEDY-33 driver installed?
LabVIEW DSP Module 1.0 - Windows 2000/XP - SPEEDY-33 USB Driver
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
(3,514 Views)
