How do I process the following:
I have three strings with three different labels that I'd like to dispay in one text box.  Any suggestions?
(2,909 Views)
I hope this is what you are looking for.
If not, give us more information.
Thomas
Message Edited by becktho on 07-14-2005 04:04 PM
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,907 Views)
Sort Of,  I was looking to add the label also, so for this example Label = String 1 and String Value= String 1 Would display:
String1 String 1
So if I had label= A: and the string value = healthy, it would display
A= Healthy
(2,898 Views)
I see - this is just possible if your strings are controls / indicators. This allows you to access the text of the label using a property-node.
See the modified vi.
Thomas
Using LV8.0
(2,891 Views)
Thanks...this one works.
(2,881 Views)
