How do I play CD audio tracks using LabVIEW?
I need to be able to play and stop tracks from CD's. Is it possible. I know it's easy to play wav's but I need to play the source.
(4,272 Views)
if you know how to use system DLLs from LabVIEW then you may try to use MCI commands located in windows/system32/winmm.dll. These command allow you to control multimedia devices in your PC.
The example of how to play CD tracks is located at
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/multimed/mci_6lrg.asp
Also you can read there another info about MCI.
If I find time today I will send you an example.
Good luck.
Oleg Chutko.
(4,272 Views)
Thanks Oleg
I've had a go at using the system DLL's but am not familiar with how to use them so I'm having some trouble. If anybody could send me an example I'd be grateful.
Coxy
(4,272 Views)
I've made an example for you based on MCI command
mciSendStringA from winmm.dll
This example plays the specified track from CD.
The idea is in sequential sending of the next strings to driver:
"open cdaudio wait"
"set cdaudio time format tmsf wait"
"play cdaudio from T1 to T2"
"stop cdaudio wait"
"close cdaudio wait"
The example is attached and works fine on my PC.
Good luck.
Oleg Chutko.
(4,271 Views)
Good job indeed!
Alberto
(4,271 Views)
Hi Oleg,
Thanks for that. It works great!
Coxy
(4,271 Views)
