How do I open and close vis programmatically?
I want to open and close a vi with a switch control. What is the best way to do this?
(2,652 Views)
Probably the easiest way is to utilize vi server operations. Vi server will allow you to open a vi and close a vi programmatically. This is a great example that is built into LV. THis should give you some ideas. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,652 Views)
