How do I move my block diagram code into sequence structures without breaking all the lines?
How do I move my block diagram code into sequence structures without breaking all the lines? I have a small bit of code that needs to be execute at the very end of a loop, but if I try to move the contents of my loop into a sequence structure all the lines break... and I would rather not have to rewire EVERYTHING again.
(4,073 Views)
You could just draw the sequence structure around the code.  That wil autocreate the tunnels for you.
(4,068 Views)
Thanks, that works. Also, is there a way to say, select an object or wire on the block diagram, and delete everything that is connected to it?
(4,065 Views)
You can triple-click a wire to select all of the branches, then delete it, but that won't select all of the things it's connected to.
You can also select object(s), right-click, then select "Remove and rewire".
Not 100% sure that covers what you were asking to do though.  Your wording seems a bit ambiguous.
(4,060 Views)
