How do I modify an Image Navigator Image?
I'd like to modify one of the symbols in the image navigator by adding color to it and use it on a Labview panel. I can easily export or copy the image to a graphics application and add the color or otherwise modify it, but when I put it back into the image navigator and then place it on a panel, it has an opaque white, rectangular background. Is there a way to eliminate the background or make it transparent?
(3,067 Views)
May be you will find an answer here
Hope this helps.
CC
Chilly Charly    (aka CC)
(3,032 Views)
Thanks! I had seen that post go up right after mine, coincidentally. The .png format seems to be the answer.
(3,020 Views)
