How do I make the "abort" button show? (I cannot click "stop" in the operations pull-down.)
Just going through the data flow, it appears we missed a For loop we should have included.
Try changing the 1D WDT output to this. Then send it to an XY graph.
If the data looks correct, we can go from there.
Cory K
Message 32 of 40
(2,147 Views)
What is the VI that the dt*I and Y are plugged into called? The one that looks like;
Message 33 of 40
(2,143 Views)
That is the 'bundle' function.
In your palette, it is here:
Programming >> Cluste, Class, & Variant >> Bundle
Cory K
Message 34 of 40
(2,140 Views)
The program will not let me make the Waveform Graph outside of the for loop, it says there are mixing signals, I can make it inside the for loop however.
Message 35 of 40
(2,137 Views)
That is incredibly strange.....
That is exactly how you are supposed to build a multi-plot XY graph.
Each plot should be a cluster of an X array and Y array.
Then you build an array of all the clusters.
Does anyone know why this isnt working for the OP?
Cory K
Message 36 of 40
(2,099 Views)
Want me to put up my whole Block Diagram?
Message 37 of 40
(2,095 Views)
Sure, that would help.
Cory K
Message 38 of 40
(2,093 Views)
Haha, sorry for massive mess, I dont know how to shrink it...
Message 40 of 40
(2,088 Views)
