How do I load an rtm (Run Time Menu) file dynamically ?
I want make my menus translatable. I want to setup different rtm files (for the different languages) and call the rtm file dynamically in the LabVIEW diagram.
(4,746 Views)
There is a LLB here:
ftp://ftp.ni.com/support/labview/vis/windows/5.0/rtmfunc.zip
to load RTM files. Give it a try. It is for LV 5.0 and I don't know if it still works for 6.x. Good luck.
LabVIEW, C'est LabVIEW
(4,746 Views)
Thanks for the quick reply. That's all I need!
(4,746 Views)
In labview 2016 ,you can use programming ->application control->vi server reference and property node->RT menu path dynamic load rtm file.
2020 - 2003 about 20 years😂
(2,749 Views)
