How do I keep trailing zeroes before a value?
Hi guys:)
I'm afraid this will be the first of a series of question as I stumble into my first complex program. Until now I've only done smaller scale, but this is more heavy.
The program will do a series of test for 10 circuits attached in 1 panel. Each circuit have their own serialnumber the user have to input in my program.
The serialnumber have a letter first (A = year 2010, B = year 2011 and so on). After that there is a five digit number.
Example: A00001, A00002, A00003 ...... etc.
Because there are 10 serialnumbers I would like that user inputs the first serialnumber: A00001. Then my program automatically increments the serialnumber by 1 for each circuit. Since the letter is changed per year I have put it as text to the left of the numeric control, so the user only have to input "00001".
My program increments the serialnumber correctly and I can see the serialnumber for each circuit. The only problem is:
What I want to see:
User input: 00001
SN1: 00001
SN2: 00002
SN10: 00010
What I see:
User input: 00001 (Changes into 1)
SN1: 1
SN2: 2
SN10: 10
Labview removes my zeroes to the left of the value. Any ways to change this? I tried to change from DBL till i32 or u32. I have only managed to get zeroes after ",".
I could probably make the whole input as a string, but then I cannot increment it so user have to input 10 serialnumbers. Where I work it is very important that the testcrew use as short time per test as possible.
Thanks and regards,
Even
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,414 Views)
Accepted by topic author EvenDeejay
Just give Format string as "A%04d" in the numeric control ->Advanced Editing mode.
-Kumar.B
(3,404 Views)
Properties -> Display Format - > Use Minimum Field Width -> 5, Pad with zeros on left
- Rkll
21964iF8D31349D2E0AEA5
(3,400 Views)
Both worked so Kudos till you both, but I have to put one as solution so I put the first one.
Even
Topro AS
Norway
(3,390 Views)
