I am trying to write VI's that use USB-8451 aliases, set up in the MAX utility. I save the alias name as "USB-8451". This usually works, but when I try to use another USB-8451 I use the following procedure:
To change NI 8451 unit out:
1: Goto C:\vxipnp\winnt\nivisa\visaconf.ini
2: Delete USB-8451 Row
3: Change NumAliases Row -1
4: Save
5: Plug in new 8451 to the computer
6: Gog NI's Measurement and Automation
7: Go to the USB device and rename the alias to "USB-8451"
As I mentioned this usually works. But currently I'm working on a laptop where the alias doesn't seem to be registering. Any hints?
