How do I insert the Date in time into my file?
(3,099 Views)
Use Get Date/Time String from the Time & Dialog palette. Concatenate it with your data string (however and wherever you want) that gets written to the file.
(3,099 Views)
How owuld I save this file in different Intervals? ie; save data every 30 min. or 60 min whateve the user chooses.
(3,099 Views)
Give the operator a front panel control to enter the Save Interval. Use a shift register on your While loop (initialized to a Double = 0) to hold the Last Time Saved. In your loop, call the Get Date/Time in Seconds function (from the Time & Dialog palette). If the current time - Save Interval > Last Time Saved, save the data and update the Last Time Saved.
See the attached LabView 6.1 example.
(3,099 Views)
Could you put it in labview 6i please
(3,099 Views)
(3,099 Views)
