How do I input a floor/ceiling to find an index?
Hi all,
I'm still fairly new to Labview, so please bear with me if this has a very simple answer. I have an xy graph; the x is 'time' and the y is 'phase'. I want to determine what my phase is at a given time. I would just use the Index Array, but the 'time' array is not in integer values (i.e. index "10" might be something like 9.2 ps). What I would like to do is use Search 1D Array for the indices with a 10 ps floor/ceiling, and then interpolate the phase value for 10 ps. However, I cannot figure out how to do a floor/ceiling. In the mean time I'm working around it, but I would really like to be able to do this.
Thank you!
(8,141 Views)
Take a look at the Interpolate 1D Array function. It takes a fractional index as input and does linear interpolation. You find it in the Array palette.
(8,127 Views)
If you are just looking for a simple floor or ceiling operation, you can use the following: Round To +Inifinity and Round To -Infinity.
They can be found in the numeric palette:
If someone helped you out, please select their post as the solution and/or give them Kudos!
(8,123 Views)
Accepted by topic author kebrown
Use the Interpolate 1D Array and Threashold 1D Array.  This is assuming your X is sorted in an ascending order.
(8,113 Views)
Look at "Threshold 1D Array", it pretty much does all that you're trying to do.
-DP
New Controls & Indicators made using vector graphics & animations? Click below for Pebbles UI
(8,109 Views)
Thank you so much, this is exactly what I needed!
(8,090 Views)
