How do I increment a value that is part of a string?
I am trying to send a command to the comm port and then read data from the comm port.  I need to get 256 bytes at a time, incrementing the string I am sending after each section of data.
For example:  I send the string QD 20000<CR>00     Where  <CR> is a carriage return.
The device interprets this as 5144 2032 0000 0000 0D00 00
I need to then send the next command, which is QD 20010<CR>00   or 5144 2032 0000 0100 0D00
followed by QD 20020<CR>00, etc.
I am splitting up the string, then concatenating it after incrementing the one bit, but when I do this instead of incrementing by 1, it jumps to 31, then 32, etc.
Any suggestions would be appreciated.
(5,315 Views)
Try this in 7.0 format. It uses format into string.
(5,308 Views)
Thanks for the help.   I think I was over complicating the problem.  Your solution kept it nice and simple.
(5,285 Views)
After looking through the data, the example you have provided doesn't work as I thought it would.
I believe the reason for this is that when the string is being sent in the example, it is sending the 20000  as decimal, and the device is interpreting it as "3230 3030 30" and the increments as "3230 3031 30, 3230 3032 30, 3230 3033 30, etc".
I need to be able to send " 3200 0000 00, 3200 0001 00, 3200 0002 00, etc".
Any other suggestions?
(5,274 Views)
Yes. Don't mix ASCII and Hex when you give your command format.
Instead of  QD 20000<CR>00 you should have used, for clarity, QD 2\00\00\00\00\0D\00 where \xx is the character of hex value xx.
To cast the 32bit value into a 4byte string (*not* formatted to decimal) use the function Flatten to String.
LabVIEW, C'est LabVIEW
(5,264 Views)
Thanks,  the flatten to string function worked perfect.
(5,239 Views)
