How do I import a VI into another VI in Labview 8.2
I have 2 VIs which work fine on their own ... Now I need to have the 2 working together
Is the a command or do I need to cut/paste??
(5,902 Views)
Hi CYCLONENUT,
As i understand your problem, you need to create a subVi. information on how to do that can be found here.
I hope this helps please let me know how you get on.
Ben B.
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
(5,898 Views)
I would also suggest:
To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. There are also several Technical Resources. You can also take the online courses for free.
(5,873 Views)
