How do I get the address of a LV array?
Hi!
I try to pass a 1D array of ShortInt to an external DLL. I found many solutions for C DLLs (using the Call Library Function Node) but this doesn' work for my COM / ActiveX DLL. The external function expects a simple integer value as reference pointer to an array. The array is created in LV and will not be resized by the external function.
Any ideas how I can get the address of my array, send this pointer to the DLL and get my array filled with data that way? I tried typecasts (array => int) but they don't work that way.
Thanks!
(3,016 Views)
hi there,
you can use following controls from the controls palette for COMing or ActiveXing:
COM: "refnum"->"Automation Refnum"      right click "Select Active X Class"
AX:     "Containers"->"Active X Container"  right click "Insert ActiveX Object"
refer to "Windows Connectivity"->"ActiveX" from the "VI, functions and How-To" LabVIEW Online help.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,996 Views)
The problem is not accessing the COM-DLL. This works fine. The DLL I have handles a datafile, I can access different integer and string-fields with the COM DLL, the only thing that doesn't work is getting data from the file into an array. The DLL-Method expects an pointer that points to an already initialised array.
The Call Library Function Node automatically passes the address of a connected array as a pointer, how can I do that with a COM-DLL?
Here's the documentation of the function I want to use:
virtual long CMCSAStream::GetRawDataOfChannel(short *pData,long lIndex) [virtual]
Get raw data of a single channel.
Parameters:
pData pointer to data array of shorts (size must be determined before calling GetData.
iIndex: index to channel (starts with zero!)
Returns:
number of Data values read from the file, 0 if data is not a raw data stream
(2,971 Views)
Hi M.C.
Did you try to just wire your array to the Call DLL function input, configure the input for array and
array format to pointer ?
(2,928 Views)
