> would I go about programming something like this? I have heard of
> others doing things like this but I am unsure of how to program
> labview to send out ASCII codes to a PCI card to move motors.
Look in the manual to see get familiar with the sequences of codes you
need to write, and more importantly, where you write them to. I suspect
a memory location, but it could be a socket or port.
Each of these locations will have a slightly different way of accessing
it. Once you know, search devzone for how to do it on linux, or post
back here.
After you can send the codes to the right location, you probably want to
build a state machine that simplifies the interface and prevents certain
actions from taking place. Now determine which buttons or
keys perform
which actions and use either the event structure or the older polling
for control changes to affect state changes in the state machine.
I'm summarizing here assuming that you know what a state machine is and
why you'd want to use it. If I'm assuming too much, do some research
and post again with more specific questions. Also be sure to look at
example VIs as they show how to respond to UI actions.
Greg McKaskle
