How do I get AI Temp TC back?
How do I get my AI Temp TC back?  It has disappeared and repairing my driver did not fix it.  Please help!
Kenny
(3,145 Views)
duplicate post.
When you post the same question 3 times, you just irritate people.
(3,132 Views)
I apologize.  I am new to this and I'm just trying to figure out how to use this system.  I am a research assistant at a University and have no engineering background.  I am just trying to figure out what these professors want and deliver.  I apologize again for any inconvenience.  I tried to find where I could delete the duplicate messages, but couldn't.  Tell me how and I will delete them.  Thanks.
Kenny
(3,129 Views)
Hi Kenny,
I'm not sure how it happened, but all the pins on the CreateChannel.VI have been rearranged.
Here is the easiest way to fix it:
  1. Delete the CreateChannel.VI  (it's in the middle of all the broken wires)
  2. Remove the broken wires by pressing Ctrl+B
  3. Place a new CreateChannel.VI down where the previous one was (it is found on the Function Pallet >> Measurement I/O >> DAQmx)
  4. Wire the controls to the corresponding pins on the CreateChannel.VI  (It looks like Physical Channel 2 - 5 are not used)
  5. There are two pins from the CreateChannel.VI that go into the case structure.   Task Out and Error Out.
Once you follow these steps, your VI should work again.
Thank You,
Nick F.
(3,097 Views)
