How do I do this?
Hi guys. I am new to labview. I need to display this. If number 1 is greater than number 2 , display (number 1 minus number 2 ).Please help me out.
Message 1 of 13
(4,880 Views)
Start with some LabVIEW tutorials. The rest will fall into place.  Good luck.
Message 2 of 13
(4,868 Views)
I am unable to do it . I have tried many times. Is there any solution for this?
Message 3 of 13
(4,858 Views)
It's really trivial. Show what you have tried. You have also left unexplained what to do in false state (hint).
Message 4 of 13
(4,855 Views)
Ok . So I am unable to connect it to the subtract which I need it to display the value after my current load demand subtracts the value of the contracted capacity.
Can someone show me how?
Message 5 of 13
(4,848 Views)
Oh . If it is false . Then it will just display a 0.
Message 6 of 13
(4,844 Views)
Hi diver,
why do you want to connect the result of the comparison to your 2nd subtract node, when you want to calculate "Number1-Number2"?
You should program, what you have described before - actually you aren't doing this…
Message 7 of 13
(4,828 Views)
Everything you have is backwards. Don't you think the comparison should be done outside the case statement?
Message 8 of 13
(4,808 Views)
Hi, is there anyone out there who can help me, I am trying to generate a best fit line after taking some data from a DAQ 6008, after capturing  a transient response of the form y= a*(1-exp(-b*x))+c, i need to fit a best fit line, but keep getting error from the curve fitting VI, because is an iterative process, i keep getting this error input matrix is singular, any ideas?
Message 9 of 13
(4,805 Views)
Hi ET,
there would ba a lot of people to help you once you create your own thread instead of hijacking a totally unrelated one…
Message 10 of 13
(4,801 Views)
