How do I do a URL Mapping on variables contained within a cluster constant? [Web Service]
I am trying to create a web service and I would like to URL map some controls that I have wrapped up in a cluster control.  I have three identical cluster controls, each with a unique name - but they contain variables that do not have unique names. i.e. ClusterA.dog, ClusterB.dog, ClusterC.dog, ...
How can I distinguish among these variables when trying to URL map them?
Thank you for any help.
(3,007 Views)
Accepted by topic author 5thGen
Hi 5thGen,
Unfortunately, clusters are not supported in WebServices. You will have to give each input a unique name.
(2,976 Views)
Thank you for the response.  That is unfortunate that clusters are not yet supported.  Is there a way that I can approach this situation using tables?  I am unfamiliar with using tables in LV but I would like to be able to access variables as if they were in an array of arrays.  For example, rather than using a common name to reference a variable I could use a common location in an array.  So, using the example I had before, each column could be a unique cluster (though they would no longer be clusters) and each row could be a variable (dog, cat, ...).  I could them bundle them up by name and reference them later in the code.  Is it possible to build this kind of table (or array of arrays) using URL maps and if so how would I go about doing it?
Thank you
(2,973 Views)
Sorry 5thGen,
Arrays are not supported either for URL mapping. The only data types you can use are ones that only hold a single value at a time. You will have to split up your variables for the URL mapping. This, however, is an excellent suggestion to our R&D department and I encourage you to submit this and other suggestions to them. They look at these and decide what new features to include in future release based on how often it is requested.
(2,962 Views)
