How do I distribute my xml error code file?
Hi all,
I am using labVIEW 8.2 Prof. on a RedHat Linux.
I built an application where I made the tick in the labVIEW build specification "Advanced->Copy error code files". Nevertheless when I start my new application and force an error which is actually defined in my error code file I get the message "This error code is undefined. ..."
My error code file is saved twice:
1. in /usr/local/lv82/user.lib/errors which works as long as I am using the VIs and not the actual application and
2. in <project-folder>/errors
Anything I missed?
Johannes
(2,960 Views)
Hey,
Is it working in development environment and do you test the executable then at the development machine?
Christian
(2,877 Views)
Please put your error definition file into the folder:
/usr/local/natinst/share/errors/
(2,849 Views)
