How do I determine which version of windows os is installed on the computer that my application is running on.
I need to determine which version of windows os in on the computer running my application to make some minor adjustments to a subvi.  Is there a programmatic way to determine this using Labview.
(5,918 Views)
Place a property node (App control palette) on the diagram and select the Operating System>>Version Number property.
___________________
Try to take over the world!
(5,916 Views)
madg
(5,911 Views)
For posterity, I found it useful to map the version number to the actual name of a Windows version. That information is here:
Operating System Version
(5,255 Views)
Or, use the Application property node Application>OS>Detailed Name.  Although I can't say anything about its output on other-than-Windows OSes.
By the way, I think you win the "reviving old thread" award today Smiley Very Happy
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
(5,245 Views)
See attached VI.  depending on your admin rights you might have to add command to run as admin.  Tested on both Windows 10 and Windows 7 and works.
(4,880 Views)
shrink down to this. due to lacalization of windows that change, for example, "system type" in "Tipo sistema: x64-based PC" in Italian.
btw it works. thanks.
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(2,946 Views)
