06-15-2004 01:50 PM
06-17-2004 09:15 AM
06-17-2004 01:14 PM
06-18-2004 10:35 AM
06-18-2004 11:16 AM
06-22-2004
03:14 PM
- last edited on
08-19-2019
08:09 PM
by
pcerda
I did a little more google-searching and found a couple newsgroup postings that were even more useful than the original link. The articles are embedded in the diagram of the two implementations given below.
User-controlled inputs are:
1) original floating point value
2) requested max error
3) max allowed value for numerator
4) max allowed value for denominator
Outputs are:
1) floating point value of rational approximation
2) numerator of rational approximation
3) denominator of rational approximation
4) actual error
5) boolean flag telling whether error spec was met
6) # of terms / iterations to achieve approximation
The first (and recommended) implementation is based on a continued fraction repr
esentation of the original floating point value. In my testing, the slowest execution time was about ~5x the fastest.
I left several array indicators on the front panel that helps show the progression of the approximation through all its iterations. So you can check out successive approximations for pi or something.
The second implementation is based on iterating through a sequence of "Farey" fractions. It's fastest case can be several times faster than the continued fraction method, but there are other cases that slow it down by a factor of 1000+. (It seems to be worst when the floating point value is very close to an integer, a situation that may arise fairly often.) Because of its virtually unbounded execution time, I advise against using it. Consider its inclusion here to be solely for educational purposes.
As suggested earlier in the thread, I'll post the continued fraction version as a piece of example code.
-Kevin P.
09-27-2018 07:23 PM
After recently linking to this thread, I noticed that I could no longer download the example vi using Chrome. I decided to repost, and in the process I did a little bit of minor tweaking as well as making a wrapper that helps translate from the terminology of rational approximation with its talk of numerators and denominators over to the terminology of DAQmx with its talk of buffer sizes and # of waveform cycles.
In the process, I also wound up upcompiling the code to LV 2016. FYI.
-Kevin P
09-27-2018 08:43 PM
More than 30 years ago, before the era of PCs, when 65kB was as much memory as you could address directly, I programmed a "sum of sines" algorithm for a behavior stimulus that covered a frequency range of 0.02 - 1 Hz. The technique we used was to generate a waveform of 16,384 points that represented the 7th, 13th, 23rd, ... (all relatively prime harmonics, either 8 or 10 of them) played back so that the fundamental ranged from 0.001 to 0.01Hz (some of these number might not be quite right -- it's been a long time). The point is you need to have a buffer large enough to have an integer number of periods inside it. If it is a single frequency, you need one period's worth of points.
11-03-2018 09:52 PM
And yet another update. The topic came up again, I pointed here, and in the process realized that the wrapper utility I posted recently didn't have any terminal connections. I added those and then added yet another layer to demo how to connect it to an actual AO sine wave generation task. The zip below contains both the vi's posted above (after I added wiring terminal connections to one) plus a vi that integrates them with an AO task.
-Kevin P
