How do I create an array of 16 * 16 with information that I read from the card
As Greg pointed out, you could use more shift registers to achieve it.  I guess you are new to LabVIEW, try to check out few NI Examples under Help-->Find Examples...  Hardware Input & Output --> CompactRIO-->DAQmx-->Analog/Digital Inputs.  This will give you some idea on how to use fetch data from singlechannel and multi channels.
Ajay MV
Message 11 of 17
(1,676 Views)
Hi Ajay,
who's "Greg"?
Message 12 of 17
(1,652 Views)
Oh, c'mon, it's a simple typo -- GerdW -> GredW (which makes no sense at all!) -> Greg ...
Bob Scorch
Message 13 of 17
(1,627 Views)
@GerdW wrote:
Hi Ajay,
who's "Greg"?
Oh.. sorry dude.. mispelled your name.. GerdW...
As Bob Schor pointed..
Oh, c'mon, it's a simple typo -- GerdW -> GredW (which makes no sense at all!) -> Greg ... Smiley HappySmiley Very Happy
-Ajay
Ajay MV
Message 14 of 17
(1,601 Views)
I still can not understand how I'm building a 2-dimensional array 16*16.
Every time I read 8-bit data converts to a number, and I need to put it in the next  place in the array
Message 15 of 17
(1,577 Views)
Hi Fnachum,
as has been said before:
- initialize a 16×16 array, store it in a shift register
- every time you read a new sensor value you replace one element in the array using the known coordinates and the sensor value…
This is very basic array handling in LabVIEW and you should have learned this by going through (free) online resources offered by NI and creating small VIs learn LabVIEW "by doing"…
Message 16 of 17
(1,553 Views)
This is what GerdW is getting at. It's a quick-n-dirty example to demonstrate what you need to do. I would run this and examine the code and modify as you see fit.
Message 17 of 17
(1,544 Views)
