How do I create an XY Graph where X=type_string, Y=type_double?
I would like to plot measurement Y against serial number X.  Measurement Y is of type double, and the serial number is just a string.  When I bundle an array of X and an array of Y into a cluster, and try to feed it into the XY Graph icon on the block diagram, I get a broken wire.  I need the flexibility of plotting some numerical value against a string that I create.  This is possible in Excel, is it possible in LabVIEW 2009 SP1?  If so how?
17755i3B693D66D0745B62
Richard
(5,065 Views)
Accepted by topic author RichardBallantyne
This has come up several times before. No, the graphs do not support that. You basically need to cheat. See this post for an idea.
(5,058 Views)
in LabVIEW charts and graphs are based on a cartesian system.  You need a magnitude (scalar number) for each dimention.  You can associate a scalar numeric value to each unique string (think- ring or enum controls or an array index) but you must have a magnitude for each dimention.
"Should be" isn't "Is" -Jay
(5,048 Views)
The solution that smercurio_fc linked will probably work for me -- thank you smercurio_fc.
To be honest, this solution is rather cludgey.  I wish NI would implement something more elegant by expanding the list of acceptable inputs to the XY Graph to include strings.
Thanks again,
Richard
(5,029 Views)
Then you should vote for the idea. Smiley Wink
(5,013 Views)
