How do I create a Waveform Chart with scrollable time/data history?
Hello All
I have a Waveform Chart that displays my data points as my test is running.
What I need to do is have the chart store the times associated with each plotted value.
Example 1: If the chart is running, I'd like to use the scrollbar/ graph pallete to rewind the chart and tell me what time/date in chart history did each data point occur.
Example 2: If I found a defective point in an over the weekend test, I would like to scroll back thru the chart data to that point and see the time/ date it occured
Can anyone help me with this Waveform Chart scenario? Im using LV 8.5.1
thanks!!!
J
Message 1 of 13
(4,456 Views)
Use a property node to set the X-Scale format and minimum at the start of your test.View Context help to get the format description, 7 is time and date.
Message 2 of 13
(4,447 Views)
yes Ive tried this...but it doesnt work in my attachement...do you know why?
thanks
J
Message 3 of 13
(4,443 Views)
yes Ive tried this...but it doesnt work in my attachement...do you know why? thanks J
Message 4 of 13
(4,442 Views)
Your right, I didn't try it in a loop. That Sucks! I found an example, try this: in LV 8.5
Hope this helps.
Message 5 of 13
(4,433 Views)
yep, tried the Real Time also.
Not really what I wanted....I just need some way to keep track of points and associated Time Stamps.
So when I scroll back thru the chart data, the Time Stamp appears visible to the user.
Any other way to do this?
J
Message 6 of 13
(4,430 Views)
How about looking in the shipping examples? Do a search for 'charts'. Run Real-Time Chart. The key is understanding what the offset and mulitplier mean in a chart or graph and what minimum and maximum should be used for.
edit - see that the shipping was posted. It works for me. The actual time of acquisition is written on the x axis.
Message Edited by Dennis Knutson on 10-09-2009 12:35 PM
Message 7 of 13
(4,414 Views)
Hi J,
See if this does what you need.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 8 of 13
(4,400 Views)
This version generates it's own data.
steve
Message 9 of 13
(4,384 Views)
Did you set the history length? If your chart displays 400 points and youset the history of 8000, you can scroll back in time roughly 20 x the length. If set the chart to collect a point every minute and set the history for 18000. This will keep a history of 30 hours.
Message 10 of 13
(4,379 Views)
