How do I count from 10 down to 0 then back up to 10?
I'm controlling a stepper motor with LabVIEW and I would like to advance it from a position of 14 to 0 in increments of 1 then back up to 14 in increments of 1 and stop it there. Any suggestions on how I could set up a loop to do this. The routine will be part of a basic state machine and each time I enter this state I would like to do the increment.
Thank you.
(4,555 Views)
Accepted by topic author chuck72352
14 or 10?  The subject says 10 but the message says 14,Smiley Wink
Just keep track of whether you're counting up or down in a shift register.  Put 1 in the shift register if you are to count up, -1 if  you are to count down.  Just add that value to the count you are storing in another shift register.  When you hit one end or the other, take the negative of it and put it back in the shift register.
(4,549 Views)
I"m not sure exactly what you mean, but I'll try and figure it out.
Thank you.
(4,544 Views)
I just figured out what you meant.
Thank you!
(4,538 Views)
Attached is my solution.
(4,531 Views)
Not exactly what I was thinking, but that works.
Another idea.  Search for the Ramp Pattern function. (Actually a polymorphic VI).  It lets you create an array that either ramps up or down by whatever increment  you want.  Two of those back to back (one up, one down) and concatenate the arrays to each other should also get you there.
(4,491 Views)
Thank  you.
(4,475 Views)
