How do I copy memory to a Labview Array via CVI?
I would like to declare a singly dimensional array in Labview and pass that array handle to CVI for population.
I have the declaration of the array as such;
typedef struct
int32 dimSize;
uInt32 Numeric[1];
} peakArray
typedef peakArray **peakArrayHandle
and the function declaration uses "...,peakArrayHandle Array,.." as the pass-in value.
So I (foolishly) think I can simply declare an array size using;
(*Array)->dimSize = numVals;
..and then pass a value to the container using;
(*Array)->Numeric[counter] = value;
It runs fine..once. Then crashes LabVIEW on the second run..So, I'm sure there are a few LabVIEW specific memcpy functions I'm missing here.
I've read thru the pd
f dox, and there aren't sufficient examples for what I want to do...and I've combed thru the limited amount of CIN and DLL example code you provide, but witness differing techniques for implementing this.
Help !!
Kindest regards,
Warren
(3,425 Views)
You are resizing the array size but not allocating mem for it. You need to use "DSSetHandleSize" or "SetCINArraySize" function to resize the array. I usually use the DSSetHandleSize for arrays also.
CIN MgErr CINRun(peakArrayHandle Array) {
int32 i,ArraySize=100;
DSSetHandleSize(Array,sizeof(int32)+ArraySize*sizeof(UInt32));
(*Array)->dimSize=ArraySize;
for (i = 0; i < ArraySize; i++)
(*Array)->Numeric[i] = i*10;
return noErr;
you need to have extcode.h and labview.lib for this. Hope this helps, For more details description consult the Code interface reference manual.
A Rafiq
(3,425 Views)
Hi !
Ok, this is a DLL, so I thought I wasn't supposed to use the CIN()'s with DLLs? Is that true?
Anyway, I tried this;
NumericArrayResize(uL, (int32)1, (UHandle *)&Array, (int32)(counter - 2));
..and it seems to work. But I still get crashes when I try to write the array value to (*Array)->Numeric[]. I tried using MoveBlock, but that crashes too.
Here's the "real" problem..I am writing the DLL in CVI..but I can't figure out how to invoke the debugger when testing the DLL in Labviews..do I have to use printf's for debugging, or is there some way I can get the CVI debugger to "awaken" when I run the DLL from Labview ??
Kindest,
Warren
(3,425 Views)
Yes you still have to use the mem functions. I haven't use the move block. I have created DLLs in VC++ and i use the DSSetHandleSize function all the time.
here is an example of DLL function
// Dynamically resizes a 1-D array to size and fills with data
int32 Dynamic1DArrayResize(TD1Hdl in_array, int32 size)
MgErr error;
int32 i;
// The first 32 bits are used for size information, and then the array comes after the size
error = DSSetHandleSize(in_array, sizeof(int32) + size*sizeof(float64) );
if (error != mFullErr && error != mZoneErr)
(*in_array)->dimSize = size;
for (i=0;i < size;i++)
(*in_array)->arg1[i]=(float64)(i +.5);
return 0;
else return -1;
(3,425 Views)
