How do I convert an earlier numeric array in LabVIEW 5.x or earlier to a Waveform Data Type in LabVIEW 6i?
I am trying to convert old data arrays in LabVIEW 4.x & 5.x to the new Waveform Data Type in LabVIEW 6i. Please Ref. Doc. LabVIEW 6.0 Upgrades Notes page 7-8 as a source.
Has anyone ever tried it?
(2,721 Views)
try to use Buil Waveform VI after loading old data from files ...
LabView Help : "Build Waveform
Builds a waveform or modifies an existing waveform. If you do not wire an input to waveform, Build Waveform creates a new waveform based on the components you enter. If you do wire an input in waveform, the waveform is modified based on the components you specify. This function is expandable."
(2,721 Views)
