How do I connect Bluetooth adaptor with LabVIEW?
How do I connect my bluetooth adaptor with bluetooth SMiRF silver. Using a USB cable I could receive data from my arduino connected to my gyroscope. I want to do it now using bluetooth and need help knowing the necessary tools to create my block diagram. Please any help will be appreciated. (Please see attached block diagram).
kind regards,
Okor29
(2,739 Views)
I believe I answered this question the first time you asked...
In general these devices should install a virtual serial port and once two modules are paired the fact that they are bluetooth becomes irrelevant .
Communicating through them is the same as communicating with any device on a serial port.
=== Engineer Ambiguously ===
(2,713 Views)
Yes it has no paired but my readings stay stagnent (please see attachment below). Also, I get this error. Do you know where I can find the configuration setting?
LabVIEW was unable to connect to the LINX device using the following settings:
Interface: Serial
COM Port: COM5
Please make sure that the LINX firmware is loaded on the device (Tools>>MakerHub >>LINX>>Firmware Wizard) that there are no other open connections to the device, then check the configuration settings, and try again.
(2,706 Views)
