How do I combine two arrays into one?
I am trying to combine two byte arrays into one. What function do I use that will put in the information in the same order just combined?
(3,796 Views)
I think you'll have to use the Build Array VI. Don't forget to tick the "Concatenate Inputs" when right clicking on the VI otherwise you'll get an n+1 dimension array (n is the dimension of the arrays you want to combine).
Hope this helps !
Julien
(3,796 Views)
Thank you so much Julien this worked great!! Molly
(3,796 Views)
Julien,
Used LV for years.  Never knew that (concatenate inputs).  Wouldn't believe the lengths ive used to get around it.  Thanks Smiley Very Happy
(3,363 Views)
battler. wrote:
Julien,
Same here! Smiley Wink I actually learned about it taking a sample test for the CLAD.
Richard
(3,343 Views)
