How do I combine Agilent 34970A VI.
I am using downloaded Agilent 34970A VI drivers from the NI site in Labview 7.1. I am using the "HP34970A EZ Resistance.VI" to collect ON/OFF switch data and the "HP34970A EZ Voltage.VI" to collect pressure information. I have been able to get them both to work independently. Now I want to turn a solenoid on/off using a combination of data from both. How do I combine them into one project. I am new to Labview. Thank-you in advance.
(3,802 Views)
To start with, you should check the LabVIEW Learning Center and take one of the many tutorials, books, classes, etc. to get an understanding of LabVIEW. What you want to do sounds pretty simple and basically what you do is drop these separate VIs into a new one. Now they are subVIs in the new main VI. How you wire them together and incorporate other functions is going to depend on a lot of things but hopefully you'll have a better understanding once you take some kind of task and look through some of the numerous shipping examples.
(3,801 Views)
Hi roberto,
   can u send me the 34970A driver for labview 7.1..
Labview 8.2
Learner
(3,641 Views)
You can get it yourself at http://www.ni.com/devzone/idnet/default.htm.
(3,636 Views)
I Can't download Agilent 34970A drivers for LabVIEW 2010 from NI Website. If some one has already download please post the attqachment.
Thanks in advance
(3,130 Views)
