How do I clone elements in a 1D array?
I have an array that has single values of elements such as [1,2,3] and I want to convert it to the format [1,1,2,2,3,3]
I'm trying to use a for loop with 2 counts but for some reason it says that I have too many dimensions.
Attached is my image.
(3,960 Views)
Learn about For loops, indexing terminals (on the input side, they allow you to "step through" your array one element at a time, while on the output side, they "construct" an array for you).  This will certainly be covered in the LabVIEW tutorials available for free (except it does cost a little time and effort on your part).
Let me paraphrase your problem in a way that should suggest a simple (and extremely efficient) solution:
For every element of the input array, put two copies into the output array.  Hint -- you can do this with a single For loop with one other LabVIEW function (guess from which Palette) inside the loop.
[Colleagues -- please let ylevental try to figure this out -- this is the best way to learn ...]
(3,945 Views)
Accepted by topic author ylevental
There is a simple primitive, Interleave 1D array that would do that for you.
Hope that works!
Wisdom is the principal thing; therefore get wisdom: and with all thy getting get understanding. Proverbs 4:7
(3,936 Views)
Thanks!  I didn't even know this existed before you showed me 😄
(3,916 Views)
No problem, there are so many  functions in LabVIEW that its extremely hard to keep up, if not impossible!
God Bless!
(3,908 Views)
