Use the reference from when you opened the vit to change the FP.Title property. This will display the new name in the title bar of the referenced VI, but will not actually change the name of it.
If you want to actually change the name, you'll need to use the Invoke Node method 'Save Instrument' with a path specifying where to save it and with what name.
These two properties are shown in the attached image.
Ed
