How do I change the array to the correct format?
I have to check this on my other machine but I think it may work for my use case. Thanks
@Vinal_G wrote:
Done.
Message 11 of 18
(2,074 Views)
Can you give us a little bit of background information.
  • What does the input array represent?
  • Where does it come from?
  • What is the output array used for?
That kind of information would g a long way helping us understand and solve the problem.
At the moment is is just a puzzle to look for pattern where only a single example is available.
There are millions of possible solution that covert your input array to your output array. Most likely only one is correct.
Message 12 of 18
(2,064 Views)
Accepted by topic author mark.eckhoff
OK, I thought that Vinal's solution above looked overly complicated. Here's what I came up with instead... (LV 2013)
...seems to work just fine. 😄
Message 13 of 18
(2,053 Views)
Alright,
I have some background to this issue to clarify for everyone.
The array that I attached corresponds to a collection of parsed data files. I have been working on a sorting function to export to an Excel Spreadsheet that sorts Flow Rates from different devices into a sorted Row Column Array. The Column of 0's is there to actually work as a null and has no significance whatsoever but to clean up my data (I remove this at a later step).
I will attach my code too to clarify some more I have another VI previous to the compilation of this one that Parses the data from text files and sorts them into an array as well.
The reason for the sorting process here was to sort the indicies of the sorted arrays to line up in my output array accordingly so they would correspond to the correct sample number if there was a previous sample that did not contain a value under that particular Flow Rate Column.
I hope this works to clarify my particular problem.
Thanks for everyone's help and I hope that what you gave me works - I'll let you know later today.
Mark
Message 14 of 18
(1,969 Views)
My code makes a few assumptions about the data, for example there cannot be any missing integer. e.g. if the dataset does not contain any "5" at all, the code would fail. If there is a possibility of missing values, a few very minor changes would need to be made.
Message 15 of 18
(1,946 Views)
Your assumptions are correct for my use case. There will always be a numerical progression that doesn't skip integers for this case. Thanks again.
Message 16 of 18
(1,943 Views)
altenbach,
Ran into a problem that I found that I can't understand why it does this in your code.
Here is a screenshot showing the problem.
For some reason it cuts out my last index at the end. Do have an idea what is doing this?
Mark
Message 17 of 18
(1,762 Views)
Your array does not match the required specification for my code to work, because now your output array needs to be larger than the input array. If this is a possibility, you simply need to pad the original array with a sufficient number of rows of zeroes (e.g. using "reshape array") before starting or do some other conditional manipulation.
That should be easy to fix. See how far you get.
Message 18 of 18
(1,723 Views)
