How do I center a picture in an indicator?
I have picture data (in this case generated by a draw transfer function subVI) that I would like to display in a picture indicator. The indicator is larger than the actual picture will typically be, and I would like to find a way to center the picture in the indicator. Any thoughts?
(2,843 Views)
Before you call "Draw flatterned Pixmap.vi" to display the picture, modify the image data cluster, add an offset. The attached vi demonstrates how to add a horizontal offset.
George Zou
http://gtoolbox.yeah.net
George Zou
(2,833 Views)
