How do I call a Run-Time Menu option using a Boolean Control?
I'm using Run-Time Menu and I want something to happen when I select 'New File' from drop down menu. I want the same function to happen by a button click. I've attached an image where there is an illustration for this.
Pradeep.
(2,801 Views)
Accepted by topic author Pradeep_Patil
use an event structure with value change event case for that button and inside that case put the same function which you using for RTM selection
(2,788 Views)
Thanks G K.
Pradeep
(2,774 Views)
