How do I calculate CRC?
Hello all,
I would like to know how to calculate the checksum in Labview.
Ex. code is appreciated.
I have a couple of syntax ex. in VB and C/C++ as follow.
B. Generating a checksum for a binary request
Calculate the accumulated sum of the bytes in the vector.
Get the value of the sum modulo 65536 (10000 hex)
The CRC is the 2 complement of the result.
If lSum is a variable holding the accumulated sum, then
CRC = (Not (lSum Mod &H10000)) + 1 (VB syntax).
CRC = (~(lSum % 0x10000)) + 1 (C/C++ syntax).
Note that the CRC is a two-byte value (while in ASCII format it is a one-byte value).
Kind regards
Andreas Svensson
(5,741 Views)
Please do a search. This question has come up many times before, and numerous CRC VIs have been posted.
(5,724 Views)
(5,696 Views)
Hi Andreas,
Your description is for a checksum calculation not for a CRC.
Message Edited by K C on 11-27-2009 04:49 PM
(5,682 Views)
Thanks KC for pointing that out.
Just in case you were looking for the CRC and not Checksum..  below are links of interest...
I didn't check the contents of the examples, but it is supposidly for a CRC16.
http://forums.ni.com/ni/board/message?board.id=170&message.id=142902
another from Shane:
http://forums.ni.com/ni/board/message?board.id=170&message.id=66015
(5,670 Views)
