How do I build this array?
I have a vi that generates two time intervals in ms. One interval is between the time a light turns on and button 1 is released (time 1). The other interval is the time between the same release and the press of button 2 (time 2).
The vi loops through the light flashing/button press sequence until the number of set trials equals
the number of correct trials.
I want to build an array that records time 1 and time 2 for each trial. Something like this
0.1200 1.3123
0.2400 1.8979
0.3423 2.4567
etc.
The way I've got it, the array ends up being just time 1 and time 2 from the last trial.
0.3423 2.4567
How do I set this up to do what I want.
My vi is attached.
(2,815 Views)
You need a 2D array, so on the front panel indicator right click on it and select "add dimension" then you need to "build" the new results into the array. (see attached image)
(2,804 Views)
If you only need the array at the end of the run, simply wire your 1D array to the right loop boundary, right-click on the tunnel and select "Enable Indexing". Now create an indicator to the right of it. It will be a 2D array of all trials.
(2,797 Views)
Hope this help!
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,784 Views)
