How do I autosize columns in Excel using ActiveX in Labview
I found the ExcelExamples.llb but nothing that describes this. My data is sometimes bigger than the default column width.
thanks.
Message 1 of 9
(6,366 Views)
The first resource to check for methods and properties (related to MS Office environment) is the integrated Visual Basic help.
Anyway, in this particular case, you need to "obtain" a column/row collection related to the worksheet you are using (for example, either by .Columns("A:I") or .Range("A1:E1").Columns) and call ".AutoFit" method.
Hope this helps
Message 2 of 9
(6,366 Views)
Can I get a little more info? Maybe a small vi as an example? I still don't get it.
Message 3 of 9
(6,366 Views)
Find attached Write Table To XL.vi. I included a "columns" property and a "autofit" method (for our range - in this case, all columns). If you want a custom range, use "Range" method instead of "columns" property.
Hope this helps ... better
Message 4 of 9
(6,366 Views)
Thanks!!!
Message 5 of 9
(6,366 Views)
After playing with activx I found the way for all options to work
Not working without sequence
With sequence all working well, any other activx
Message 6 of 9
(3,090 Views)
The reason your code doesn't work "without sequence" is you are not using the Error Line.  You would greatly improve your LabVIEW code (and help others to understand it) if you always make your wires go left-to-right (and never bring an "output" wire back underneath a function and make it "appear" to come out of the left side as you do in Excel Get ActiveX).  You want to do the Excel Save Report after you close the Columns reference -- wiring Error Out from Columns Reference to Error In of Save Report (and wiring the Error line through the preceding functions, as well) would fix this!
Message 7 of 9
(3,077 Views)
Nothing to add. You right.
But still, activex is working with autofit.
Thanks for the point.
Message 8 of 9
(3,074 Views)
Alexela,
     As a "beginner" with LabVIEW, I used Sequence structures until my mentor taught me that Error Lines do a lot more than help report Errors.  In the next phase of my "LabVIEW Life", I had a very negative opinion of the Sequence structure, and almost never used it (except when using some of the Time functions).
     Until a few years ago when I was introduced to the "magic" of FPGA programming, where the Sequence structure took on a necessary "sequencing" function.  So it's all knowing "when and where" the Sequence is appropriate ...
Message 9 of 9
(3,060 Views)
