How do I append information already on a table?
I have a vi that is running multiple loops, not simultaneously. I show the data from the first loop in a table on the front panel. I then exit that loop and enter to the next and I want to append the data from the second loop on the table keeping the data in the column that is already there. Any help would be appreciated.
Troy
(2,518 Views)
the data in the table is just an array ,so you can append you new data to that array and use the value property node of the table to write your new array to the table.
(2,515 Views)
