How do I add the channel-name to mixed signals?
I want to save a XY-Signal to a tdm-File and import it into DIAdem.
So I merged the X- with the Y-Signal and connect the merged-signal to the "Write To Measurement File" VI.
In DIAdem I can see both signals but their name are "Untitled" and "Untitled 1". I don't know how to fix that.
If I use the low-level storage VIs, the other problem occures. I can give the X and Y-Channels my desired names, but they are in waveform - I want them as numeric channels in DIAdem.
So how can I give the mixed-signal the names
or
how can LabVIEW say to DIAdem that it is a numeric signal?
KR
Lukas
Message Edited by schmiddy on 01-11-2008 04:31 AM
(5,424 Views)
Hey Lukas,
To name your dynamic signals you can see this KB "How Do I Rename Signals in Dynamic Data?".  After you name your signals appropriately, you could then merge them together and write to a tdm file.  DIAdem will then be able to read the channel names from the tdm file.  I hope this helps.
Best Regards,
Software Engineer
Jett R
(5,397 Views)
Thank you!
Lukas
(5,368 Views)
