How do I add text files to the installer?
I'm working with a VI that reads from several text files.  I'd like to be able to create an installer that includes those files and installs them in the correct location.  This location is located in ProgramData (Vista OS).  I thought about hard coding the info in the VI but I really need the ability to change the files on the fly.  Is it possible to include the text files in the installer?  I'm using LabVIEW 8.5.
(2,783 Views)
Hello tguenzler,
if the text file is in your project structure than you can add it to your exe file.
Mike
(2,782 Views)
Ok, I got it to work.  Thank you very much for your help!
(2,772 Views)
