How do I add a scroll bar to an array?
I want to take a 2D array and change the row its is in with a scrollbar so that in a another array index I can pull out individual number from each row.
So I have a CSV file [time,1,2,3,4,5] and I want the user to able to vary the time with a scrollbar.
Thanks!
(4,156 Views)
Just kidding, I figured it out but for some reason it only scrolls though 8 vaules, not that 1000's that I need it to...
(4,147 Views)
sofiekyle,
Pop up on the border of the array control, select Visible Items >> (Horizontal of Vertical) Scrollbar.
The scrollbar only sets what is visible.  It does not set the selection point, which you would need to pull out data.  There are several property nodes which can help you manipulate the data.  It is not clear exactly what you are trying to do, so I will not guess what might work for you.  Try some things, read the help, and see if you can get it to do what you want.
Lynn
(4,146 Views)
A scrollbar is a cosmetic UI element that does not modify data (e.g. vary time) or "pull out numbers" (whatever that means).
If you can only scroll through 8 values, maybe you need to transpose the array to swap rows with columns.
(4,142 Views)
right click on one of the arrows on the scrollbar, "data entry"
(4,125 Views)
