How do I acquire info from Contect help?
Hi all.
I am creating a user-interface where I want to display the desciption of of any item when the mouse cursor is on the actual control item... something similar to the Context Help Window..... Would I be able to acquire what info is in the context help window to output somewhere else ?
(2,963 Views)
You could use the Desc and TipStrip properties of the control that you mouse is pointing too.
Here I have used an event structure with the Mouse Enter event to trigger a read of the properties.
Does that help?
David
Message Edited by David Crawford on 07-12-2006 08:10 AM
(2,961 Views)
Yes.... that's exactly what I wanted!
Thanks David
(2,954 Views)
