How do I a smallint SQL database value using the Database tools?
I'm using the Database Toolset with Labview 7. I'm building up a parameterized Query to a Stored Procedure in my SQL Database. It doesn't appear that smallint output types are supported because zero is always loaded into the variable.
Is this correct? I'm I doing something wrong?
Feedback welcome... thanks!
(2,820 Views)
It's probibly not an issue with datatypes since LV has far more datatypes than most databases. What exactly are you trying to do? Are you getting the 0 when running the stored procedure? Could you perhaps post a bit of code (LV and SQL) that demonstrates the issue?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,820 Views)
