How do I Format DateTime Data in WHERE Clause of SELECT Statement Using Execute Query.vi?
When I execute this statement in MS Access, it is a valid statement and my data is returned from my MySQL Database
SELECT a.TestDate, a.UUTModel, a.UUTGeneratedSN, a.TestID, a.FTResult
FROM TestDatabase a
WHERE(a.TestDate BETWEEN #04/10/2019 12:00:00 AM# AND #04/17/2019 11:59:00 PM#)
2019-04-18 10_38_06-2019_04_18_10_37_28_Access_S200_Final_Test_Database_C_Databases_S200_Final_Test..png
But when I run this in LabVIEW using Execute Query.vi, it complains about the # signs around the DATETIME values. How can I format this BETWEEN statement so that LabVIEW correctly queries the DATETIME data type?
MySQL Table Properties
LabVIEW Error
2019-04-18 10_35_29-Execute_SQL_Query.vi Front Panel on FPY Tracker.lvproj_My Computer _.png
(8,375 Views)
I've never used # and its been awhile since I had to use MS Access, but it looks like you need []..
FROM TestDatabase a
WHERE(a.TestDate BETWEEN [04/10/2019 12:00:00 AM] AND [04/17/2019 11:59:00 PM])
OR
FROM TestDatabase a
WHERE(a.TestDate >= [04/10/2019 12:00:00 AM] AND a.TestDate <= [04/17/2019 11:59:00 PM])
MS Access isn't standar SQL syntax, I don't think the BETWEEN function works so second method is likely better.  You should also check MS Access for the date time format expected - https://support.office.com/en-us/article/examples-of-using-dates-as-criteria-in-access-queries-aea83...
(8,361 Views)
Accepted by topic author evaneer
Thank you for the fast reply. The brackets didn't work but your formatting suggestion gave me an idea to check the DATETIME format syntax in MySQL.
https://dev.mysql.com/doc/refman/8.0/en/datetime.html
Apparently even though the DATETIME visually looks like
The format actually looks like
2019-04-10 00:00:00
So I adjusted my query to look like this:
FROM TestDatabase a
WHERE(a.TestDate BETWEEN '2019-04-10 00:00:00' AND '2019-04-17 23:59:00')
This worked and returned all of my desired data. So for all future readers of this, if querying a DATETIME column from a MySQL database in LabVIEW, the syntax is 'YYYY-MM-DD HH:MM: SS' (ignore the last space between : and S, rich text formatting kept changing this into a :S emoji)
(8,349 Views)
Go to your forum profile's preferences and turn off the automatic emoji's, then you won;t see that problem.  Profile Name >> My Settings >> Preferences >> Display >> Emoticon type ->  None.
If everyone turned off automatic emoji's, or better yet, NI just disabled them on the forums, then no one would complain about these things again.
(8,324 Views)
