How do I 24 bit binary data in two's complement to a signed decimal number
This is driving me nuts...  I have a gyro spitting 32 bits of data at me..  The first (MSB's are status bits)  I have stripped these off
and left myself with a 26 bit data string that is in two's complement.  Of course the positive convertion works fine.....
but how do I have Lab View deal with the negative numbers ??
(7,565 Views)
I don't quite understand what you are asking.
You have a binary string that is 32 bits coming back from an instrument.
Is this a floating point single precision value (32-bit SGL) ?
Why do you only have 26 bits left?
And what is "twos compliment"
Cory K
(7,554 Views)
Is you data in a I32 format?
Cory, this is the format http://en.wikipedia.org/wiki/Two's_complement common for signed integers
Check and see if this work. It is from the top of my head 😉
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(7,547 Views)
Eh that was wrong try this. And the edit time was up 😞
(7,536 Views)
After stripping the k MSBs, left shift k times.  Then an I32 correctly interprets the twos complement.  Divide by 2^k.  Result is an I32 containing the value sent by the instrument.
Lynn
(7,528 Views)
