How develop the final application exe file that will work on non-installed labview PC
I have developed one application in labview (I have application builders and professional license).
I generate the final exe file by tools  -> Build Application exe file from VI -> done
But this application exe file is running only on labview installed machines. Its not running on other PC.
For running in other PC what should I do.
with regards and warm welcome,
Ramamoorthy S
Message 1 of 11
(4,287 Views)
Did you install LabVIEW run time engine in the PC where you want to run the exe?
Also make sure you have also installed any other drivers required by your program.
______________________________________________
Kudos are welcome
Message 2 of 11
(4,281 Views)
Hello
As mentioned already, you will need LabVIEW Run Time Engine corresponding to the version of LabVIEW in which you developed the application.
Also, any required device drivers for NI products or other third party products, or toolkits that are used in the application must be installed.
it would be easier if you build an installer like you built the application. You can build an Installer and distribute it to other systems for usage.
Regards
Freelance_LV
TestAutomation Consultant
Message 3 of 11
(4,278 Views)
How can i check the installed other softwares.
Ramamoorthy S
Message 4 of 11
(4,263 Views)
I have not understood your question. Could you please explain it again?
when you open the build specificaitons for an Installer, you can select the software drivers that you will need under Additional Installer section.
Regards
Freelance_LV
Message 5 of 11
(4,256 Views)
Gogenini,
Your signature has a picture that points to
file:///E:/Users/Sulakshana/My%20Work/Cert/CLADLOGO/Certified-LabVIEW-
Obviously, that doesn't exist on anyone's system but yours, so it shows up as a blank box with a red X.  You might want to fix that.
Message 6 of 11
(4,227 Views)
you may check below link for the procedure....
http://digital.ni.com/public.nsf/allkb/41561F98D96235FC8625708F00552ADF
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
Message 7 of 11
(4,210 Views)
Thank You Ravens.
I removed it from my signature.Do you still see it?
Kudos are welcome
Message 8 of 11
(4,179 Views)
Nope.  It is gone now.
Message 9 of 11
(4,173 Views)
Accepted by topic author ramji44
Hello Ramji,
As you mentioned, EXE is created by you and its ruou nning fine on the PC where you have created it as LabVIEW is present there.
So for non- LV PC, Kindly create a Installer and add additional software/installer required by your EXE.
Look at the link for reference.
http://www.ni.com/white-paper/5406/en
Bijay
CLD
Message 10 of 11
(4,170 Views)
