How create basic test
Hey, I'm newbe in LabView. How can I create basic test. Where I upload a file with questions. There are 300 questions. The program has to draw 10 random questions from the file and show them. At the moment I know how to load a file and show all questions in array. He added my file. Does anyone know how to do it? Thank you in advance for your help.
Message 1 of 10
(4,862 Views)
Hi bury,
load all items, then select 10 of them in a loop.
To select random items you may create a ramp from 0 to (size of array -1), then apply Shuffle function, then just take the first 10 entries of the shuffled ramp as indices for your items...
Message 2 of 10
(4,838 Views)
Yes, I know how do it with hardcode data. But how do it with file data. Could you see the txt file and perform this task?
First I must upload data from file to array. What do I have to do in the next step?
Message 3 of 10
(4,833 Views)
Hi bury,
load the file using ReadText as an array of lines. Then do as written before...
Message 4 of 10
(4,824 Views)
Accepted by topic author Bury
Hi bury,
using LV2018 you can even apply Shuffle on your string array of items, so no need for an additional loop as I described before:
Message 5 of 10
(4,766 Views)
Wow, I will try this and let you know
Message 6 of 10
(4,763 Views)
You would connect a pH electrode and see if the reading is >7. 😮
Message 7 of 10
(4,751 Views)
I will try this but I can't connect function. And why array subset isn't string format?
Message 8 of 10
(4,703 Views)
Your question is unclear.  The VI you posted doesn't show you trying to connect any function and failing.  Nor does it show the Array Subset function.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 9 of 10
(4,687 Views)
Try this. And next, start your homework earlier. Create the VI yourself, you will learn something even if you just copy it exactly.
mcduff
Message 10 of 10
(4,684 Views)
